Instead of window switch?
Just get the same size/style switch and mount it in there..
Edit: I guess I kinda misunderstood the original post. Got confused.
"make it LOOK like you have TCS".. ok but no, that switch has a pcb under it and is very low current however if you put a micro switch there under the button, then yes, it would look like TCS and yes, you could use that. I'm sure the parts can be found at a bone yard. Same goes for the conv. top switch. Last edited by Todd157k; Nov 29, 2006 at 11:17 AM.
