Nitrous Dry Shot GOES LEAN!!!!
I have the LPE 100 maf and LS2Edit, which I think was the issue (bad tables, maf sensitivity, etc.). It looked OK on the dyno at 75* temp, but sprayed it once on the street under 60* and it fell on its face with detonation. Finally said screw it and sold the dry kit. Also, I had 47lb injectors and LPE Stage III heads w/ small 224 cam, and I was spraying 12" from the damn MAF with just a 75 shot at 1100psi.
Good luck.
Good luck.
1100 is gettin up there for bottle press too!
He has NX nozzles, which have the logo on the injection side. I can see from the pic they are in correctly.
Vinny
My eyes aint as good as they were...wait to you see the magnifing glass mod I to to the NX jet kit I got from ya!Beer
Good luck.
The DC should have been higher than that according to some of the other threads.
The DC should have been higher than that according to some of the other threads.Its not too far. That distance should work just fine. However I am sure that when you moved yours closer it probably went richer.
But heres what is likely going on with the original posters setup....especially on the larger vette and truck MAFs.
1 in 10 dry nitrous setups seems to end up like this....way too lean. Half of the dry setup are leaner than I would like to see and are in the 12.5-13.0 range.
Its all about where the center of the stream of the highest density nitrous is centered as it passes through the MAF.
Even though it may appear the dry nitrous fogs the entire path...it has a high density area as it exits the nozzle...especially when its that close to the wires in the MAF. So what can happen....is the majority of the nitrous shoots right past the MAF wires without hardly registering. Just having nitrous go through the body of the MAF is not good enough...it must come into contact with the wires.
The closer you are...the more at risk you are of having this happen. The closer you are the more critical aiming the nozzle correctly becomes because the high density stream is narrower the closer you get to the nozzles exit. It fans out with distance.
The farther away...the more foolproof it is...but the more leaner on avg you will become.
In this case...something about the direction of spray is not allowing the nitrous to hit the wires with enough density. Youll either have to turn the nozzles...or repostion them or both. If you turn them...be sure your line is not twisted....because if you turn the line and nozzle and get it working right...the line will eventually turn back to where it was at a later time and make you lean again.
I would still check out your fuel pump for sure....but generally when a dry shot is lean like this...its all about placement and spray patter across the MAF.
Dave
Robert
Good luck.
Robert
Robert
new fuel filter and it was great. thing that pissed me off was the dealer told me they did all of the reguar maintainance before i bought it, but that, plugs and eerything else was all factory...bastards Hoses are all -4 from the Noid to nozzles (-3 ends on the hoses, custom from HSW)
Be interesting to see if Nozzle postion is the culprit, although I am sure you don't want to make your Blackwing a pincushion
Fuel pressure may be the culprit, but these cars can usually support 450rwhp+ stock pump, and from what Ive read, the 01 Z06 (my car) has a better fuel system than the 02-04...i read this somewhere, but im not sure how true it is.
I didnt want to have to monitor AFR and FP at all times with this setup. My goal was a 100 dry shot with the car otherwise stock. My new setup will be wet 100 shot with a FPSS...so I wont need to monitor afr and fp with that.
The one thing I was looking forward to is the ability to tune timing with the dry shot, but oh well, maybe I will do the IAT trick mod and reduce timing with that
Dave
new fuel filter and it was great. thing that pissed me off was the dealer told me they did all of the reguar maintainance before i bought it, but that, plugs and eerything else was all factory...bastardsIt's really to bad you threw in the towel so easily. Similar conditions and problems with a/f can happen to a wet hit also, however, changing jets for a/f can be easier than relocating nozzles to a correct position.
We recently did a dyno of my new dry kit, and a buddy did a dyno of his new plate kit. Well my dry was in the ball park and adjustable that day. My bud's wet went way lean, mid 13's all the way through. He/we did not have the right jets to get it into line. So moral of story, he will be paying for another dyno trip with a hand full of jets. So which is more easy/cheaper to set up, this day it was the dry that was non problematic whereas the wet gave us issues. Also, the wet hit had a nice intitial lean spike (fuel system), and the dry did not.
As for 1 in ten set-ups not working correctly, or going lean. Well I certainly respect Al's input, but this time I totally disagree. What we have been finding is nozzle placement is key, and I have not seen one yet that couldn't be set with proper nozzle location. If the MAF is working for your n/a needs, then it will certainly work for your dry spray needs. Remember guys, 3 to 4 inches has proven to be the location, with nozzles in the neck.
Good luck to ya though, and hope things work out. Keep us updated.
Robert
