Nitrous Dry Shot GOES LEAN!!!!
Definately check ou tthe fuel system first. However...I have installed and myself run many many dry setups. Some spraying as much as 325 rwhp..ALL DRY.
I can tell you that i have turned nozzles and made the hit go richer or leaner. Its actually semi common knowledge here as Robert will tell you.
I do believe he could get the system to work just fine by repositioning them so they hit the wires better.
And just to correct your statement to be sure we are on the same level...its "slightly turned nozzle"...not "slightly turned injector". Turning the injectors will have no effect.
Actually I can and have proven the fact that nitrous missing the wires will cause a lean condition...and the closer you get to the wires...the more at risk you are of going VERY lean if the nozzles are not aimed right. If they are aimed right...the closer you get the richer youll be.
The farther aways the less likely youll overshoot the wires but youll be leaner even with the best contact of nitrous over the wires with the greater distance. In most any application there will be a "best location" that will suit all the needs of a well installed dry kit.
Robert and many other LS1tech guys have done this as well.. It really is as simple as relocating or aiming the nozzles better.
For the record..I am more partial to dry setups on the LS1 than wet up to approx 250 rwhp shots. And I have used dry shots up to 320 rwhp with great success. And My next kit will be dry as well. They just have a few things like this that must be checked on. And the vettes intake is a bit more finicky than the F body. But I have seen this happen in both.
Robert
Looking forward to seeing his results. I'm taggin this thread. LOTS of good info here.
I'll keep this thread updated with the wet results and pics and such. Hell, maybe there is a prob with the fuel system and this is all a waste of time. Doubtful though.
Robert
I hope that makes sense.
IOW...im just being a little conservative to what I tell others is ok.
And quit being a baby Robert...300+ shot for the vette!
Robert
you could try something.... go into your maf airflow vs. frequency chart and find your max airflow value on moto( may be in the low 300's on your stock setup?)
so say if your max value N/A is 315g/sec find the freq. hz that shows 340g/sec and change every Hz. value above that to 512 g/sec see if that adds the enrichment you need.
I am not sure if it will work for you but it is worth a shot if the spray is not pegging the maf due to not reading the spray properly it may only be picking up a small amount of it.
right now I have my first dry shot shoot my maf reading up to 470+/- and my second pegs it i did this by setting my first shot up so it does not hit the maf fully. It works pretty good and it gives me a good af through two stages of spray and leaves me the option of not running the second stage if there is not enough traction to support it and it does not go pig rich assuming that the second stage is coming on.
( the proof is in the amount of holes in my callaway CAI
) Last edited by rmitchell242; Dec 2, 2006 at 11:02 AM.
So, on the spray runs I had to let off each time because it would start spraying at 13:1afr and work its way up to 14-15afr.
btw, president Bush causes dry systems to go lean because he's the devil.
The solution is to elect a different president.
this type of post annoys me weather or not I agree with it Here is the math for a good idea on what an injector can do when leaning towards the 80% rule (which, imo, you can surpass for a 1/4 run with no issues).
(Anticipated bhp x .5) / 6.4 = min inj to meet 80% rule
So, add 12% drivetrain lose to your goal rwhp of 670 which equals 750flywheel hp.
750 x .5 = 375
375 / 6.4 = 58.58 min inj to meet 80%
Not sure if the Racetronic injectors are like the SVO 42's (I run these) which are actually 47/48's at our fuel pressure compared to the lower bar that Ford uses. Any way looks like your goal of 150 dry may be a little short in the injector area. Maybe a smaller hit would be fine if your injectors are rated at the Ford psi?
Robert
Robert
