Solenoid mounting?
Thanks in advance.
I mounted mine to the cylinder head but I used some silicone mounts to insulate the mounting plate from the engine heat. The mounting plate is warm but comfortable to hold onto after the engine is up to temp. but the bracket that mounts to the head is so hot it will burn you if you try to hold on to it. My guess is that my solenoids stay at least 100* cooler that they would if they were not insulated.
Thanks,
Matt
Thanks,
Matt
http://www.harrisspeedworks.com/shop...cat=372&page=1
Thanks,
Matt
Anybody else had this occur? And where can I pick up a longer fuel line if HSW doesn't just send me one?
Please PM me your name.Matt
