how much is "safe" to spray on 11.5 comp.
Old Dec 3, 2006 | 09:32 PM
udlose99ta's Avatar
Default how much is "safe" to spray on 11.5 comp.
new engine (lt1) will have almost 11.5 comp with forged srp's. Was thinking of a 200 wet shot (maybe tnt f1, or somthing from nitro dave). Also what is a good stall and gear for that shot.
combo:
le3 heads/cam kit
42# injectors (bigger?)
stock crank and rods
forged .040 srp's
impala head gaskets
th350 w/brake and 3.73's
3500 or 4k stall
Any opinions will be helpful i want to try to do it right the first time.
thanks.
Old Dec 3, 2006 | 11:03 PM
daniel6718's Avatar
42 would be fine...go wit a wet shot, and you wont need any bigger injectors...200 on srp should be fine...the stock rods wont be though...the crank will be at its limit...
Old Dec 3, 2006 | 11:14 PM
TwoFast4Lv's Avatar
I would worry about the stock rods
With good rods I would not be afraid to hit it with 200 or more
Old Dec 4, 2006 | 02:56 AM
udlose99ta's Avatar
the block is still apart, what rods should i go with?
Old Dec 4, 2006 | 08:03 AM
jldak318's Avatar
eagle h-beams, alot of people run these and these are going into my motor.
Old Dec 4, 2006 | 09:21 AM
daniel6718's Avatar
eagle h beams....
how much can you go on forgerd srp pistons?
Old Dec 4, 2006 | 09:32 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
I am running Eagle forged Crank and H-beam 6" rods, Ross pistons.
Currently at 12.2:1 CR and going to hit it with at least 250hp
as stated before the rods/crank will be the weak point....but if you make sure the tune/set up is dead on, and the fuel system can keep up, it should be fine.
Old Dec 4, 2006 | 11:37 AM
udlose99ta's Avatar
thanks guys, good info
Old Dec 4, 2006 | 11:40 AM
daniel6718's Avatar
before the thread dies, how much can srp take? 250-300? with good stand alone fuel system and NO detnoation?
Old Dec 5, 2006 | 11:58 AM
jldak318's Avatar
im wondering the same.
Old Dec 5, 2006 | 12:05 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
To get the best information on what a certain piston will handle...it is best to call the manufactuer....the SRP are the budget forged pistons by JE...I think the should handle 2-250.
Like most engine components they are rated for a HP level...If you put them in a stock LT1 they will take more than if you have a AFR headed, solid roller, stroker.
