n2o and shift
Old Dec 3, 2006 | 11:34 PM
00formLs1's Avatar
Default n2o and shift
the car is a 2000 formula a4 with a 3500 2.0 str fuddle
here is my set up daves plate with 150 jets, wot switch and a digital msd WS
i have the switch set at ON 3000 Off 6000.
the car feels so great in the window but when it stops to shift it falls on its face until it gets back in to the window.
i had a tune done by tsp back in march and that got rid of the bounceing off the rev limiter.
is it the tranny sliping or even the converter or is it just that the boost from n2o turning off is that noticable?
my mods are in sig
thanks
Eric
Old Dec 4, 2006 | 08:08 AM
mrr23's Avatar
what is your shift point set at?
Old Dec 4, 2006 | 11:26 AM
00formLs1's Avatar
they left it stock
Old Dec 4, 2006 | 12:51 PM
bjamick's Avatar
well when the window switch cuts off your losing that 150hp LOL thats y it feels like its falling on its face .
Old Dec 4, 2006 | 02:52 PM
mrr23's Avatar
well, according to my stock .bin, the factory shift point is at 6000 rpms. so, shutting it off at the same time it's shifting might be confusing the computer via the calculated torque. just a guess. turn off the nitrous at 5900 and see what happens. personally, i have mine set at 6500 rpms. that way i'm spraying through the shifts.
Old Dec 4, 2006 | 10:39 PM
00formLs1's Avatar
i have tried it at 59 and 58. i think mine shifts at 6200
Old Dec 5, 2006 | 08:06 AM
mrr23's Avatar
then it got raised, if it is shifting at 6200. set it for 6100 and see what happens.
Old Dec 5, 2006 | 09:25 AM
00formLs1's Avatar
ok i will try it.
thanks
Old Dec 5, 2006 | 05:35 PM
00formLs1's Avatar
hey mrr23. i just looked at my window switch when it was shifting and it is shifting at 6100rpms. would i risk bouncing off the rev limiter if i turn off the window at 6100?
also if i set it to 6200 would that be concidered spraying during the shift
Old Dec 5, 2006 | 05:59 PM
CAT3's Avatar
Restricted User
Yeah, the feeling like its going to die, falling on its face is normal when the giggle stops and your back to NA. Wait til you feel the difference b/w 250 and NA!
Old Dec 5, 2006 | 06:05 PM
mrr23's Avatar
no you wouldn't risk bouncing off the limiter if you shut off at 6100. 6200 would be right at the shift point, so i'd say no. setting it above the shift point, like i have is spraying through the shifts.
Old Dec 5, 2006 | 09:28 PM
00formLs1's Avatar
i think my shift point is at 6100, i tried it out eariler today and it shifted at 6100.
