Can you get away with this oops on WET?
Old Dec 5, 2006 | 11:59 AM
Todd157k's Avatar
Default Can you get away with this oops on WET?
ok.. so I'm logging runs and getting a handle on tuning. Taking several blasts up and down the fwy. I knew my bottle was running a little low (800psi warmed) but I needed some logs. I did notice (after 6 or 7 runs) that it wasn't hitting so hard, but still running smooth and still a harder hit than N/A. Looking at my logs, nothing looked too far out of whack but there were some lower numbers. I went out to check my bottle...
200 psi
Old Dec 5, 2006 | 12:08 PM
JZHeyde's Avatar
Time for a new bottle...all you would do is run extremely rich.
This is the only problem with nitrous, it runs out. You need to get a few extra bottles just in case.
-Jamin
Old Dec 5, 2006 | 07:56 PM
Robert56's Avatar
One of the benifits of running dry, you'll get added performance all the way to epmty. Whereas, the wet hit when bottle starts going low will run crapper and crapper and slower and slower. Now lets not even talk about the pooling gasoline in the intake, as it no longer has the nitrous to help atomize and carry said gas.
Same scenero works with or without a heater also.
Robert
