Bottle Pressure Questions
Old Dec 6, 2006 | 12:07 AM
nomorews6's Avatar
Default Bottle Pressure Questions
The search wasn't working, so I figured I'd just ask here ...
I have heard that nitrous many times will not be too effective if the bottle pressure isn't correct. Is there a way to make sure you get 100% of the performance from nitrous all of the time? Also, how big of a difference would there be if I was spraying from say 3000rpm to 6000 rpm from 2nd gear on? I have a stock 39k ls1 / a4 / 10 bolt and don't want to make it all go kaboom! Should a 100 shot still drop me a second with traction?
Old Dec 6, 2006 | 12:37 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
you should drop approx 1 sec from a 13 sec car
Old Dec 6, 2006 | 12:43 AM
nomorews6's Avatar
really - even if just spraying from 3k to 6k from second gear on?? Sounds good to me! What if I would be running low 12's already?
Old Dec 6, 2006 | 12:47 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
if you already run low 12's...spraying from in 2nd and 3rd only will net mid 11's....with a good tire there is no reason for you noy yo spray in first.....nothing gets you off the line like nitrous
Old Dec 6, 2006 | 12:58 AM
nomorews6's Avatar
my only concern is the stock 10 bolt and stock a4 - that is why I figured I would spray from 2nd gear only
