nitrous wiring..
Old Dec 7, 2006 | 10:03 PM
TPI TERROR's Avatar
Default nitrous wiring..
i just purchased a wet kit.. but didnt come with wiring or relays.. i just bought a relay at the local autozone and doign the wirign my self.. does this look right??
Old Dec 7, 2006 | 10:23 PM
00formLs1's Avatar
that looks right. are you going to be using a window switch or a fuel pressure safety switch? if you are then pin 85 on the relay will be for those.
Old Dec 7, 2006 | 10:35 PM
317indy
Guest
Posts: n/a
everything looks good.
Old Dec 8, 2006 | 07:17 AM
BadAssFast's Avatar
yes sir
Old Dec 8, 2006 | 10:09 AM
TPI TERROR's Avatar
hm...
Old Dec 8, 2006 | 10:57 AM
Todd157k's Avatar
Nice ride. I had 3 of them (IROC & Z28). Don't forget to take a look at your fuel delivery system vs. shot size.
Old Dec 8, 2006 | 04:33 PM
TPI TERROR's Avatar
yeah im at 50 psi of fuel with the adj fpr... 24 pound injectors.. 255 walbro pump..
Old Dec 9, 2006 | 08:05 AM
WheelsUp84z's Avatar
that set up looks right, but i would deffinately still reccomend a window switch. the rev limiter cuts fuel and if you're still spraying, it could cause to go lean and you can kiss that whole motor goodbye, so i would thing that a $100 part would be a wise investment, i mean unless you like rebuilding motors a lot? i got a MSD digital window switch for 75 shipped if you interested. also you should look into a fuel pressure safety switch, in my opinion, you can never be too safe.
here's a pic of how it should be wired up
Old Dec 9, 2006 | 11:33 AM
Todd157k's Avatar
with that 255, you'll be fine. The msd is very sound advice. After you spray, read your plugs just to make sure.
Old Dec 9, 2006 | 07:19 PM
TPI TERROR's Avatar
well i heard u dont really need a window switch for this block.. its no ls1 etc.. but ill look around..
Old Dec 10, 2006 | 10:22 AM
blacktransam's Avatar
most msd's have a soft limiter that cuts ignition.. not fuel..
