spraying on 115 lsa
Old Dec 9, 2006 | 09:46 AM
Function>Form's Avatar
Default spraying on 115 lsa
im looking into a cam with these spec's
DUR @ .050" 216*/ 224*
LIFT .551/.551
OVERLAP 53*
LSA 115*
is this an ok cam to spray with?
Old Dec 9, 2006 | 09:59 AM
N4cer's Avatar
How in the world can a cam with that low duration and high LSA have that much overlap? What formula did you use for that?
Old Dec 9, 2006 | 10:55 AM
Hennytime's Avatar
ya somethings way off, thats like a fi cam
Old Dec 9, 2006 | 05:23 PM
foggedz's Avatar
The overlap was probably computed with "advertesed druation" not duration at .05.
Old Dec 10, 2006 | 12:53 PM
sorry i just took the numbers i was given by the seller
Old Dec 10, 2006 | 01:38 PM
TATER's Avatar
Get that overlap thing figured out, but otherwise I don't see why it would necessarily be a bad cam for the juice.
Old Dec 24, 2006 | 09:31 PM
nate-roth's Avatar
Looks a good mild cam for an automatic car. Wide LSA are usually desireable for spray cars since they normally have less overlap. The exhaust duration bias is good as well for nitrous. Any brand names or other markings available from the cam. The info. you got is only half the story.
