Car acting weird after 75 shot
Old Dec 9, 2006 | 05:42 PM
c5formula's Avatar
Default Car acting weird after 75 shot
I have a 2000 TA with 224 cam and walbro 255, svo 30lbers, and a nos wet kit with 75 jets in it. Timing is being pulled out by 3 degrees with a timing tuner. I sprayed it about 5 times or so and now the car is kind of hard to start, and when I shift it acts like it has no power for a second then picks up all of a sudden. Any help would really be appreciated.
Old Dec 9, 2006 | 06:01 PM
wavrdr's Avatar
I would check your plugs as it sounds as if a ground strap was burnt off....
Are you running colder/non platinum plugs?
You "should" be running NGK tr6 or equivalent...
Godd luck!
Old Dec 9, 2006 | 06:06 PM
c5formula's Avatar
Yes Im running TR6's...
Old Dec 9, 2006 | 07:38 PM
Phlip00WS6's Avatar
It was the fuel line on the fuel pump... it was siding off. This is the second time it came off!
Old Dec 9, 2006 | 11:52 PM
81LsElky's Avatar
its always nice when its someting simple!
Old Dec 10, 2006 | 07:31 AM
CAT3's Avatar
Restricted User
This reinforces the need for a in car fuel pressure gauge. Can't recall how many times the in-tank "high pressure" line blew out of my car, or the clamp cut it, or it popped it off until I got it right. A quick glance at the gauge would have saved a lot of troubleshooting time.
Old Dec 10, 2006 | 08:11 AM
35thls1ss19's Avatar
very wise! i use mine all the time, idk what i would do without a fuel pressure gauge. i wouldn't have anythign to look at when i am goin down the track haha
