so who does have the best and fastest heater???
Originally Posted by Nick@HSW
Hey Dean,
Dan at dynotune should have all of this info. I PM'd him on Jan. 26, Feb. 2, and Feb. 5 of 2006. If its okay with you I could just copy and paste those PM's in this thread or have you review them prior to? Let me know. Thanks.
Nick
Nick
Nick,
You have a PM.
Thanks!
Dean
Since you already have a heater. I would get a bottle blanket maybe a adjustable pressure wswitch. I can not see a big enough speed difference to go from 240 to 300 watts and justify the cost. Im sure the 300 watt heater will be faster but keep in mind it will also draw more amps from the car. So you have your pros and cons both ways.
If I were to change Heaters the 860 heated bottle bracket gets my Vote...... The aluminum transfers heat fast with less amp draw and it has a adjustable pressure switch as well.
This is just my thoughts. Many vendors here have a good selection in bottle heaters... many are pretty comprable.
Dave
Dave
Is it possible to run two heaters like for instance a NX heater and the 860 brackets and tie them both into the same pressure switch?
I've never tried that, but you would have 465Watts of heat on tap!
I'll fit a bottle up and see if they actually fit together.
Vinny
Vinny
Originally Posted by LS1SpeedAddict
Is it possible to run to heaters like for instance a NX heater and the 860 brackets and tie them both into the same pressure switch?
Vinny
Vinny
Run seperate power/gnd wires. If you load up one set of wires, you'd better be using something like 8 awg wire.
240 watts @ 12v = 20 amps !!!!
Yeah, even if the car is running; hot bottle in about 2 minutes, but an even hotter alternator, and battery! haha
Originally Posted by LT-x7
Now the real question is: if they do fit togather how fast will a 465watt draw kill your battery in the staging lanes?
So, for those thinking of dual heaters, the NX is a better choice for the smaller amp draw.
A 300watt heater will heat a bottle in about 80% of the time it takes a 240watter.
Another area to look at is the transducer, this can also effect which heater you may want. We carry the NX heaters (240watt) and the CF heaters (300watt).
I have seen Matts heating sheet/specs and it does show a faster heating. Dyno Tune has a great price and a transducer that varies by only 50psi concerning on/off.
Lots of choices and things to think about on a seemingly easy subject.
Robert
Originally Posted by Nitro Dave's Nitrous Outlet
A little birdy just told me NX will be having a sale on there bottle blankets starting January 1st..
I would invest in the bottle blanket...
Dave
Dave
