Safe for me to spray? Advice Needed!!
Old Dec 24, 2006 | 01:43 PM
LS1 Eddie's Avatar
Default Safe for me to spray? Advice Needed!!
This year I just rebuilt my bottom end while I was doing my heads and cam swap. I figured it wouldn't be a bad idea since it had 97k on it to begin with. The rebuild is basically a stock one, reusing my stock crank, stock rods, and I used forged pistons this time instead. My question is, with an LT1 that will probably be making upwards of 375+ hp NA already, is it safe to hit it with a 125 wet shot like I planned? I will most likely be using HSW since they are only about an hour and a half away from me.
Nitrous gurus chime in, I'm just starting to learn about all of this.
Old Dec 24, 2006 | 01:54 PM
Lythropus's Avatar
I'm kind of a nitrous newbie but I say it should be fine. I wouldn't spray a modified engine without an upgraded fuel pump. If yours has been tuned you will need to pull some timing.
So buy a fuel pump and pull some timing if it's tuned!
Why didn't you upgrade the rods? Seems like little money now would of addressed all the shortblock weak points.
Old Dec 24, 2006 | 02:03 PM
LS1 Eddie's Avatar
I should have, but at the time I was running out of money. The guys that built my motor tested the rods and told me they were in great shape. Everything above I have already figured in!
Old Dec 26, 2006 | 10:06 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
Ed, you can put an inline pump under the car pretty simple.
125hp should not be a problem.
Just start at 100hp and work your way up.
Cheers
Dan
