Purpose of blowdown tube?
The bottle warmer keeps the bottle pressure up as the ammount of n2o in the bottle decreases. After a long run the bottle will cool down to a point where the wartmer helps build the pressures back up. Think of it like air duster. When you use it the can gets cold and the pressures drop. IF you warm it back up, like sticking it under your arm... the pressure comes back.
http://www.myls1.com
A bottle warmer is necessary for consistancy in your runs.
