Fuel puddling?
Old Jan 10, 2007 | 09:31 AM
camar0corey's Avatar
Default Fuel puddling?
How often does this happen and how? Does the fuel solinoid get stuck open or something?
I'm wodnering because I think I want to go wet, I think it would be cheaper than getting new injectors and tuning it properly for a dry shot.
Any problems running a wet shot on a LT1 manifold??
Thanks -Corey
Old Jan 10, 2007 | 10:17 AM
Nitro Dave's Nitrous Outlet's Avatar
The only possible way you can have fuel puddling is if your tune up was so rich that the nitrous could not break up the fuel. The fuel would fall out of the mixture.
With a properly tuned car puddling is not possible. The mixture is sucked through the intake and out the exhaust in less than a second.
Dave
Old Jan 10, 2007 | 10:21 AM
Todd157k's Avatar
probably won't happen...
unless... bottle pressure gets way too low.. or N2o solenoid just doesn't open... or fuel solenoid just sticks open.
Pretty extreme conditions.
