Simple FPSS question. Did a search.
Alright, I understand that my stock fuel pump runs around 45-50psi or so, im replacing it with a 255lph walbro later this month.
When shopping for a FPSS I found a nicely priced one from NOS. It says it is adjustable 25-50psi. The following is assuming I have it adjusted to 50 PSI for examples sake. Its installed properly, set to 50PSI.. Now.. that means it will only allow my nitrous to be sprayed when its at 50PSI or higher, correct?
Just trying to verify before I end up with one I cant use, even though im pretty sure I got this right. Never hurts to ask for a double check.
PN is: 15685NOS
-Lurius
PN is: 15685NOS
-Lurius
With it set at 50psi, that means once the FPSS reads less than 50psi it will ground the nitrous system and stop spraying, but YES you are correct!!!!
-Lurius
Robert
