whats needed for a 250 shot?
Old Jan 14, 2007 | 08:56 PM
yak's Avatar
yak
Default whats needed for a 250 shot?
simple question, want to bump it up. I think the noids are good for that, but anything in the likes of lines and nozzles?
Old Jan 14, 2007 | 09:00 PM
FloydSummerOf68's Avatar
What solenoids do you have currently?
Old Jan 14, 2007 | 09:04 PM
yak's Avatar
yak
nx noids. i'll check for sure tommorow, but i believe it's the iceman ones. the n2o noid is pretty big. andway to tell about the fuel noid?
Old Jan 14, 2007 | 10:23 PM
98redorangeta's Avatar
You are probably close to needing a 6an on a 250 but unless you got a a few t's in your system you should be fine. Are you spraying threw one nozzel or 2? And i assume the fuel system is up to the task. Maby consider going to a colder plug than a tr6 not sure on that.
Old Jan 14, 2007 | 10:50 PM
Slow Z28's Avatar
depending on what kit you have, the solenoids are probably fine, but the line from the solenoid to the nozzle/plate will be the factor. then of course what do you got for the fuel system will be most people's first question...
Old Jan 15, 2007 | 09:38 AM
Nitro Dave's Nitrous Outlet's Avatar
Not enough information here to help you.
If you have a single nozzle NX system with the iceman solenoids you will need the following.
1/8x-4 fitting,
SHO hose
Jets
Dave
