dual stage plate
Old Jan 10, 2007 | 07:10 PM
JL ws-6's Avatar
Race your car!
Default dual stage plate
Anyone on here using nitro dave's 90mm dual stage plate? How is it working, what do you have it jetted for, and what kind of power are you making with it? Do you have it hooked up for a single stage, dual? How much are you spraying thru it? Any distribution problems?
I am workign on picking up one of these kits from another member on here, and would like to hear from anyone that is running it, and how it's working out.
Thanks.
Old Jan 11, 2007 | 11:40 AM
JL ws-6's Avatar
Race your car!
noone's running one of these? I find that hard to believe......
Old Jan 11, 2007 | 11:51 AM
wyndzer's Avatar
I just got one, should have it hooked up in a week or so.
NitrousDirect's Avatar
You might want to check out this one
LS2 90mm Dual stage plate kit
We've gotten some awesome feedback on it
Old Jan 11, 2007 | 12:02 PM
JL ws-6's Avatar
Race your car!
I'm trying to find out from the guy that has it if it's the one that nitrous express sells, or that one you have a link to above.
I think either will be o.k. for what I want to do with it, I'm just looking for some real world results from anyone that has actually used one. The kit I'm working on getting is brand new never installed, so the guy I'm getting it from can't really help with it.
Old Jan 11, 2007 | 12:13 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Our 90mm plates have been flow tested up to 400hp per stage. I will see if I can round up some of the customers using this to help answer your questions.
Old Jan 11, 2007 | 12:19 PM
Nitro Dave's Nitrous Outlet's Avatar
We have had great feed back from the guys running any of our plates.
I did not have much time to do a search for you but here are is one on the dual stage one.
https://ls1tech.com/forums/showthrea...al+stage+plate
This is a good post that explains whats so great about our plate.
There are lots of post about our plates. From guys actualy using them. A search would probley be worth while.
Dave
Old Jan 12, 2007 | 11:25 AM
JL ws-6's Avatar
Race your car!
o.k., found out today the kit is the cold fusion dual stage plate, like the one pictured above in the link to their website....... anyone running that setup, and if so, how much are you putting thru it and what kind of results are you having?
Old Jan 12, 2007 | 07:21 PM
V-10 Killer's Avatar
Dave, do you have a pic of one of these installed? I'd like a good look at yours versus Nitrous Directs before I order a conversion replacement for my 90mm power ring.
Old Jan 13, 2007 | 12:53 AM
KrautBurner's Avatar
I'm currently having the Nitro Dave's LS2 90mm plate kit installed
I've asked my tuner to set me up for the 100hp shot, I also got the Nitro Dave's digital dual window switch
I'm hoping to get the car back next week (last I heard, we were still waiting on a few parts)
I should have dyno numbers within the next 2 weeks
Old Jan 13, 2007 | 12:49 PM
Jake@EPP's Avatar
We ran the 78mm plate on a customers car, i was impressed on the quality of the plate. +1 for nitro daves!
Old Jan 13, 2007 | 09:54 PM
I've dealt with Nitro dave quite a few times, and he's great to work with. But I have the feeling, due to the current location of my solenoids, the Nitrous Direct version will be easier to bend the tubing for. I'm still up in the air, but that's my initial impression. I still need to see a finished installation on a car though.
Here's the system I'm modifying. Out goes the power ring, in goes the plate:
Old Jan 13, 2007 | 10:23 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
here is a pic of our plate w/hard lines
This one is also using our "all-in-one" solenoid mounting bracket.....very similar to how you have your mounted
Old Jan 13, 2007 | 11:46 PM
Let us know we'd be happy to get you set up with anything you need
Old Jan 13, 2007 | 11:55 PM
Robert56's Avatar
Don't have any pics of a hard lined dual stage, but here's the basics.
Robert
Old Jan 14, 2007 | 04:05 AM
JL ws-6's Avatar
Race your car!
Robert
That's the one I am getting.
Old Jan 14, 2007 | 01:46 PM
02SOMWS6's Avatar
Hmmmmm, I just got my stand alone fuel system......maybe I need a dual stage plate to add to my tnt power ring. How will this work together with my tnt plate?
Old Jan 14, 2007 | 03:51 PM
JL ws-6's Avatar
Race your car!
3 stages? I wouldn't do that unless you're spraying a very small shot thru all of them.
I don't plan to put more then 175 thru this plate setup in fear of possible distribution problems. I know alot of people do it, but if I want to spray any more then that, I'll get a DP setup.
But, as an alternative to the ring, I think this might be a good setup.
Old Jan 14, 2007 | 06:57 PM
Do you sell just the plate? I already have the bottle, lines, noids, and wiring in place.
Old Jan 14, 2007 | 09:27 PM
Robert56's Avatar
Sure do.
Nitrous Direct Plates Only
Robert
