Dynotune Window Switch Tach Setup
Old Jan 16, 2007 | 12:04 AM
Questsi's Avatar
Default Dynotune Window Switch Tach Setup
I just finished installing it and wiring it for two stages.
For Step 1, tach setup....I set it to 00 which is for individual coils and the rpm reading shows 3000 when the engine is idling at 1000. If I rev it, it goes up but doesn't see to be correct. I have tried setting it to 01 and 08 but same thing happens. Do I run it in 04 (4 cyl) mode like the MSD WS?? I hooked up the green wire to pin 10 on the pcm.
Thanks
Old Jan 16, 2007 | 12:29 AM
Beer99C5's Avatar
Mine is set for 00 and gets the signal from the coil pack.
idle @ 700 RPM
Old Jan 16, 2007 | 07:54 AM
mrr23's Avatar
set it to 4 cylinder seeing as you pulled from the wire off the PCM.
Old Jan 16, 2007 | 03:16 PM
Questsi's Avatar
I'll try that tonight. Thanks!
