05176NOS Anyone using this LT1 nitrous kit?
I'm torn on if I want to go wet or dry, but when reading the instructions it sounds like I can spray up to a 150 shot on the 24lb. injectors???
I have a zex dry kit laying around, but I decided I didn't want to use it as you would have to disassemble the NMU to service the solinoids.
I also decided I wanted to run a FJO controller as this would cut down on boxes and switches, and maybe let my 10 bolt survive.
and yes there is something different about the SVO's.
Make sure you install the inline booster fuel pump.
Bottle heater
NGK TR6 sparkplugs gapped @ .033
MSD ignition
Good gas
I use a progressive controller
I still have the stock 10 bolt rear
I'm just seeing what is out there for dry kits for the LT1, I have a Zex kit, but I don't want to use it.
What is the difference with the SVO injectors? Just curious. I take it I wouldn't have to tune for those then if they are the same size as the stockers??
