zex wet kit
Old Jan 16, 2007 | 11:16 AM
onebadZ28's Avatar
Default zex wet kit
my brother has a zex wet nitrous kit with a 125 shot along with a red arming switch and a silver switch underneath mounted inside the car on a 98 trans am ls1, and he would like to know if you can spray the car yourself at WOT or does the system only spray itself at WOT, and is a window switch necessary. He knows that it is recommended to only spray above 2500RPM.
Old Jan 16, 2007 | 06:51 PM
99FRC's Avatar
If it's the same as mine, it has a wide open throttle switch built in. If he didn't have a window switch, the system would spray as soon as he hit WOT when it is armed (Not a good thing if you're below 2500 RPMs). Suggest he just spring for the switch. It's a lot cheaper than a new engine.
99 FRC
Old Jan 16, 2007 | 07:55 PM
dannyz's Avatar
Although some people spray below 3000 rpm and seem to get away with it, why take the chance?
Old Feb 5, 2007 | 04:36 AM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
99 FRC
I'm look'n into the same exact unit from ZEX (82026). With that Unit,........wouldn't it ONLY fire once you've reached WOT anyway?!
This is honestly where i'm confused myself. Do I need to buy a window switch if the ZEX (82026) unit only allows the N2O to fire once you've reached WOT?
If i'm mistaken please correct me cuz the way I'm see'n it ......I don't think I nessisarily need one then.
Thanx!
P.S.... If anyone has any photos of a ZEX (82026) "Wet" on their LS F-Body I'd love to see what it would look like.
Thanx again!
Old Feb 5, 2007 | 06:11 PM
*bump*
Old Feb 5, 2007 | 08:08 PM
dannyz's Avatar
It is true that it will only fire at wot.
But if you have the stock stall, chances are better the even that when your foot goes all the way to the floor, your rpm's will probably be around 1800-2200.
that could be bad.
Now if you have a stall, 3000 on up, you won't be at full throttle untill your in what's considered the safe rpm zone.
BUT......
Say you bust a u-joint,.........WHAM!!!!! you just pegged the rev limiter.
That too could be bad.Window switch is just a little bit of piece of mind.
Old Feb 5, 2007 | 09:09 PM
Awsome explination! Thanx dannyz.
