Do you need a tune for 100 dry shot?
Old Jan 23, 2007 | 10:34 AM
jeremy341a's Avatar
Default Do you need a tune for 100 dry shot?
Stock A4 99 Z28 with a lid and fast toys ram air.
Old Jan 23, 2007 | 11:44 AM
Nitro Dave's Nitrous Outlet's Avatar
I suggest checking the tune on any shot..
Dave
Old Jan 23, 2007 | 12:37 PM
jeremy341a's Avatar
What do I need to monitor other than air fuel ratio. I can do this with the predator right?
Old Jan 23, 2007 | 12:45 PM
brad8266's Avatar
monitor AFR, knock retard, and fuel PSI.
Old Jan 23, 2007 | 01:15 PM
383LQ4SS's Avatar
you shouldnt need a tune. But as everyone said..you really should hit it on a dyno with a wideband first so you can accurately check your AF ratio.
3 pulls on a dyno with wideband usually runs $75. Well worth it IMO. You can check your NA power and then your gains on the juice as well as AF ratio.
Old Jan 23, 2007 | 01:22 PM
BLNLS1/RX7's Avatar
I would like to find out where you can recieve 3 dyno pulls for a nitrous tune in the united states for $75
Old Jan 23, 2007 | 01:27 PM
383LQ4SS's Avatar
Read slower!
No one said anything abut a nitrous tune
3 pulls with a wideband to CHECK the tune. If its off...it would be up to you to figure out what your need to do at that point. may be as simple as relocate the nozzle and not even do anything with the tune.
And RevXtreme, who is a sponsor here --> charges $75 for three pulls with wideband. Just like many other shops.
Old Jan 23, 2007 | 01:52 PM
JCurtin's Avatar
I would definitely get it on the dyno. I was lean as hell with my 90shot dry. Good thing I went, the psi basically blew all of the dirt and sut from my filter right onto my maf wires. Costing me over 50hp TRUE STORY. We pulled the maf off, cleaned the tiny wires slapped it back on and my normal n/a 343-347hp numbers showed back up. Prior to cleaning the maf I put down 290.
Make sure your filter is clean!
Old Jan 23, 2007 | 01:56 PM
Z284U2TRY's Avatar
yes get her tuned.
Old Jan 23, 2007 | 05:08 PM
Robert56's Avatar
We have them. 35 bucks for first pull and 10 bucks for every pull after that. Next one is Feb 17. Turbo Tech in Tacoma.
Robert
