Wideband controller question
sorry to hijack but i am curious too
I suppose is you have single exhaust & put the sensor down strean of the Y pipe you would probably be ok. Except if one bank goes lean it will not be as sensitive as a 2 channel because the richer bank would cause the sensor to read richer than the lean bank is running.
Check the FJO website and it will tell you all that it does.
The unit comes with 4 foot leads from the 02 sensor to the control box. I put the control box under the pass. seat and bought 2-8 ft. leads. I did not know you can connect the leads together to extend them.
