Wideband controller question
My question is, do you think I should get a wideband controller w/ gauge to continue to monitor the air/fuel ratios? I do not have any tuning software such as HP Tuners. I would get the wideband controller just to keep an eye on the air/fuel while driving the car. If so are all wideband controllers going to work for this type of setup, or should I get a specific one such as the Innovate LC1? THANKS.
Dean
- IMHO.. Start with the 50 shot and work your way up. Once you're on a dyno, it will tell you everything you need to know. You're just kinda stuck with the results. Talk to some fbody guys (and Matt) about fuel delivery with 125 shots and over.
Problem is: every car seems to be a little different. Even the 'stock' tune files are different. No one has crystal *****. I had a narrowband afr gauge at first. ($40 on ebay) I got really really close with that (everyone said it wouldn't work). Now I have the LC1 from Dynotune (why theirs?? cuz they give a way free stuff on here) and found that I was SPOT ON. AFR is at 12.2 with the 150 shot. Now I get to start checking my VE tables.
Watching the guage and logging are great but if it goes lean for some reason it can happen so fast you may never see it on the guage at all and if you do you probably cannot react fast enough to save the motor. If you are data logging and it goes lean you can see it but if the motor is toast it won't save you any $$$.
If it ever saves you one time it will be the cheapest thing you ever bought. It can eliminate the need to go to the dyno when changing jets or adjusting the AFR. You can data log to see what changes you need to make and have the cut off safety net if you make a mistake. I have not spent a penny on dyno time and see no reason for me to do so.
Also if after you leave the dyno there is no guaratee the AFR will not change from time to time. In fact I will guarantee you it will.
Great product. I won't leave home with out it.
LC-1 is a tough lil bastard to get right with the grounds, the LM-1 plugs into a lighter and would be way easier to hardwire than the LC-1.
DynoTune likely has both of em in stock.
LOL Todd and I have the tuning bug now.
Nothing like logging your VE in PE making sure you have the right PIDS to nail down that AFR.
sorry to hijack but i am curious too
Also Gerald @ FJO tech support is great. (FJO makes the Maximizer if you did not know.)
