I have now started my direct port build(NXL)
#48
update: tommorow im installing my TDs and selling my current exhaust set up (tsp catted y, hooker cat back). just got paid today, and once i sell my exhaust ill have cash to plan around with... after doing more research ive added a few more things to the list.. heres the revised list
-39# injectors
-NX fuel accumulator
-Racetronix P&P
-NOS 2 stage mini progressive
-Bottle
-Cobalt or Carbon Fiber nitrous/fuel psi gauges
-AEM wideband
-Gauge pillar
-Adapters for injectors (their 04 cobras)
-edelbrock bottle heater
so those are really the necessary items i need so i can get it all up and running, tuned and what not..eventually ill buy a remote bottle opener and some other things i might have missed..im thinking since i already have 2 toggle switches, i might as well make my own switch panel.. but if i do buy one its definitly going to be a Nitrous outlet ashtray pannel.
my question now is what do i need for a purge? i believe krautburner left me some items.. i know i have this blue NX "Y" looking fitting which i believe is for the purge, what else?
EDIT: after kinda thinking about it i might as well be kinda cheap, and just buy a window switch/tps switch and save 70 bucks or what not..
give me some suggestions: autometer cobalt or carbon fiber gauges? my car has black gauge cluster (camaro) i cant decide!
-39# injectors
-Racetronix P&P
-Bottle
-AEM wideband
-Gauge pillar
#49
Keep in mind that the mini progressive will also allow you to ramp your nitrous, i.e., allowing you say 50% of your 120 shot nitrous hit at 3000 rpm's and ramping your percentage up to 100% by 4000 rpm's. (Example)
I have everything you have in my Vette, wouldnt do it any other way
#52
ive been thinking about this for a while.. if i get a progressive controller, and ease myself into a 180 shot, assuming my tune is on point, how do you think my stock shortblock will hold out?
UPDATE: few days ago sent out checks for a NX fuel accumulator, and 39# injectors off an 03 cobra.. ill get pics when they arrive.. once i get rid of my exhaust & A/C ill have more cash to play with
#53
According to Ricky at NX, LS1's should handle 180 shot all day long, however mine could not do it as my heads have been milled down quite a bit, increasing cylinder pressure quite a bit and raising my CR up a lot. Had to rejet to 120 shot
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#54
the "Y" fitting is to split the main line to be able to run to both rails. just before the "Y" fitting, you put a purge noid.
https://ls1tech.com/forums/showthrea...&highlight=NXL
![](http://stealthram.com/familypics/formula00/408/nx/assembledfront.jpg)
#55
so F*CKING Hawt !!!!
Joey,
that's what you needed, right?
that's your intake manifold, right?
when is that beast gona be lining up with my huffing goat?
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#56
i got a FAST 90mm.. that intake doesnt use the nozzles that connect to the injector.. i just started ordering parts: 39# injectors and an NX accumulator.. still waiting on selling my exhaust, once i get rid of that ill have more cash to drop. next is the racetronix p&p & mini progressive
only problem is i need to buy a clutch now, so thatll delay my plans for a little bit, but im thinking ill be ready to mess around in may
just in time for the nice weather.. we'll have to run em then
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#59
mrr23 what kinda purge are you going to use?
so all i need is a purge solenoid and some line to where i wana purge outa?
yes.
i have that y fitting and two braided lines.. how does the fuel accumulator hook up?
accumulator hooks to the rear of the passenger fuel rail.
