Nos wet black nozzle
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Riddle me this. I have a wet kit with 2 cheater noids one fuel one n20 both going to a black nozzle. The nozzle is jetted with a 65 n20 and a 48 fuel. The car is going dead lean. Not sure if it matters but fuel pressure between the noid and the nozzle is solid 57 when activated. All components are new. You think I could have a problem with the n20 holding back the fuel at the nozzle or noid not fully opening. Think we are going to change the noid out and see if that works. When the nozzle is removed and sprayed both spray like they should. Checked for trash in lines and everything else I could think of.
Thanks for the help.
You can check to see if the nitrous is pressurizing the fuel side by using compressed air through the nitrous side of the nozzle and see if you get anything coming back through the fuel side. Solenoids don't really open part way, they either open or they don't. If the plunger is swollen or otherwise messed up that may cause a restriction in flow. You may want to check the plunger in the fuel solenoid and make sure it isn't swollen.
You should check this out....I have 4 black nos nozzles if you want to buy them.
http://centralfloridastreetcars.com/nozzleshootout.html
