got some nitrous numbers (for THE Caviler of DOOM )
Old Feb 2, 2007 | 12:40 AM
KrautBurner's Avatar
Default got some nitrous numbers (for THE Caviler of DOOM )
https://ls1tech.com/forums/northwest-members/651508-caviler-doom-ftmfw.html
Originally Posted by KrautBurner
well, today after work, I took a trip down to tacoma,
go figure; Turbo Technoligys wasn't very busy at 745 in the morning,
I got my O2 bung welded in,
and threw her on the Dyno
N/A: 381.59 RWHP and 364.71 RWTQ
that's with a basic tune, (we believe we might be able to clean it up some more) running between 13 and 13.5 A/F
with the 100 shot (90mm nitrous outlet plate kit) :
nitrous jet for 100 and fuel jet for 200 I hit 504.14 rwhp and 534.33 rwtq (with a tiny lean spike at 3500rpm and dropping below 10:1 A/F past 4800rpm and staying super rich all the way up.
with the 100hp nitrous jet and the 150hp fuel jet:
484.88 rwhp and 537.70 rwtq (A/F had a small lean spike at first then dropped to 11:1 before 4750rpm and stayed flat til redline)
I'm thinking of throwing a longer nitrous line in (to give the fuel an oppertunity to hit with the nitrous)
and I already have a Walboro 255lph fuel pump waiting to go in
next money is a new clutch, drive shaft, and cv axle's
then I can go with a bigger shot
Old Feb 2, 2007 | 02:03 AM
7w/aswap's Avatar
Sounds fun.
Old Feb 2, 2007 | 02:56 AM
Originally Posted by 7w/aswap
Sounds fun.
oh, she is...
good thing I have a hookup for tires,
now I need a hookup for some juice
Old Feb 2, 2007 | 09:12 AM
Chris@NitroDaves
Guest
Posts: n/a
Nice #'s there Kraut.... I bet you are having a blast driving it. The A/F is still a little rich at 11.1 it really needs to be 11.8.
-Chris
Old Feb 2, 2007 | 11:33 AM
as far as the A/F
with both of the 100 (air and fuel) it was holding closer to 13+:1
I did the 200hp fuel jet and bottomed out the A/F gauge above 5000rpm at 10:1
and it heald 11:1 with the 150 fuel jet
I figured better safe,
I might buy some more jets to play with before the next dyno day
next month
Old Feb 3, 2007 | 07:36 AM
nate-roth's Avatar
What jets are you using for the 100 shot that put you at 13 to 1? I just installed the plate and found all the given jetting to be rich. I had to go from 62n 38f on the 150 to 62n 35f to get the afr to 11.6-11.9. For the lean spike, try using a 1ft. longer nitrous line from the solenoid to the plate than the fuel side. My fuel line is 12" and my nitrous line is 24". No lean spike.
Old Feb 3, 2007 | 08:39 AM
I will have to look at the baggie to tell you what the jet numbers are
but the 13:1 was N/A
and I am seriously thinking of extending my nitrous line (just for that reason)
