nitrous problem, plase help!!!!!!!!!!
Old Feb 3, 2007 | 10:52 PM
bowtierodder's Avatar
Default nitrous problem, plase help!!!!!!!!!!
ok heres the set up on my car, i have the nos plate system with the 150hp jets in, i have a timing tunner pulling out 3 degress at activation, tr6 plugs, and the nos mini controller (2500-6000rpm, 50% ramp to 100% in 1.5 sec.). i finally got to spray the car for the first time today, when i go full throttle i get sputters and pops for a second then it starts to pull like a freight train. i get the sputters and popping in any gear i try activating it, and when i get back on it after shifting. other than that it feels great. im wondering what is causing this? i also have a fuel pressure guage hooked up and it never drops below 55 psi, and bottle pressure was 950-1000 so i know its not that. HELP!
Old Feb 3, 2007 | 11:03 PM
sobaka79's Avatar
sounds like you need a purge kit.
i think your drowning it out with gas before the no2 gets there, purge the no2 b4 hand and it shouldnt do this.
Old Feb 3, 2007 | 11:39 PM
i do have a purge kit and made sure it was nicley purged. so it cant be that
Old Feb 4, 2007 | 01:07 AM
sobaka79's Avatar
it still sounds to me like the gas is getting there before the no2 is. could be its throwing off the maf or something to do with the pcm trying to add fuel initially.
Old Feb 4, 2007 | 07:46 AM
blacktransam's Avatar
you do have Both noids hooked to the mini controller right??
do you have access to a wide band or maybe a datalogging software to see whats going on when this happens??
Mike
Old Feb 4, 2007 | 08:53 AM
860 Performance's Avatar
Turn the progression to 0sec or start at 100%, and try it again. It will probably kick on like its supposed to.
If it works fine, then go to a dyno and watch it go lean during the pulsing.
Vinny
Old Feb 4, 2007 | 11:57 AM
Vinny
ill try this today, but its really not pulsing, more like sputters and pops.
Old Feb 4, 2007 | 01:26 PM
Robert56's Avatar
Vinny
My thoughts exactly.
Robert
Old Feb 4, 2007 | 02:08 PM
so it will only go lean if its progressivly shot but not all at once?
Old Feb 4, 2007 | 03:36 PM
Since your describing some poping while the noids are pulsing, it sounds to me like its running lean until the noids stay open. I've seen something similar before and it was way lean when the controller was pulsing the noids, then the a/f went perfect as soon as the "progressive" ended.
But the only way to know that is to to dyno it or record some wideband info. Over-the-internet diagnostics are not nearly as accurate.
Vinny
