Progressive controller for big noids
Robert
Robert
Ricky
Ricky
Not opening at all makes a little more since. If the voltage drop on that wire, is high enough the fuel noids would not open seeing how there is not enough voltage to open it.
Ricky
Also once a coil in activated and deactivate it creates a back voltage flow. So the progressive is cycle on and off on and off. The noid will only close if the magnetic feild has collapse. If the off voltage time is not enough for the feild to collapse the noid will appear to remain opened. The nitrous noids collapse could give enough back voltage to keep the fuel noid open just long enough to have the ON power hit it again. All the time the magnetic field is trying to collapse but there is enough power that if appears to remain open. Just like a fuel injector in peak and hold. It takes a good amount of power to open, but very little to maintain open.
Hope I did not butcher that too bad.
Ricky
The ground and power wires are now as perfect as I can get them, no less then 14g wire anywhere, bigger where necessary.
