Progressive controller for big noids
Also once a coil in activated and deactivate it creates a back voltage flow. So the progressive is cycle on and off on and off. The noid will only close if the magnetic feild has collapse. If the off voltage time is not enough for the feild to collapse the noid will appear to remain opened. The nitrous noids collapse could give enough back voltage to keep the fuel noid open just long enough to have the ON power hit it again. All the time the magnetic field is trying to collapse but there is enough power that if appears to remain open. Just like a fuel injector in peak and hold. It takes a good amount of power to open, but very little to maintain open.
Hope I did not butcher that too bad.
Ricky
You are cycleing the ground side, but amps are still flowing. This is what I mean buy the volts having the power to keep opening.
Never tested nos controllers. did install one once. And could not figure out why that double relay thing was in there. At that time one relay did nothing at all to the function of the system.
It will all come down to quality of connection points, wire. Not sure on the sepatate circuits, if they are completely independent of each other or not. but both wires are connected to point was my understanding.
I actually removed all the crimp connectors and soldered everything at one point because I though that might have been a problem.
The split in the noid wiring is on the left where it passes through the wiper tray.
Sorry for not getting back to the thread, but was out racing all weekend, or most of it. Anyway, I think Ricky and srsnow have covered about everything. Can you draw out how you have it wired, then post a pic? Might help some, as diagnostics over the web can be tricky. Sounds to me like the controller, or the noid? Have another noid to try?
Robert
I would have gone stand alone but theres a great program for the factory ecu Ive been using and didnt want to spend the extra $ and time tuning. The car is so mildly set up off the spray, ~380 awhp, that the standalone would end up bieng somewhat redundant. The only drawback of the software I have now is the inability to compensate the nitrous with fuel. I dont think theres too much of a difference in dry vs. wet Direct Port. Im not tuning individual cylinders here.
It outputs +12v through the solenoid ground wires at all times. I disconnected everything but the +12v in and it still outputs 12v to the SG wires constantly.
Ill upload a drawing of how I had it wired
