quick question about spraying with my cam
Old Feb 11, 2007 | 07:07 PM
99ccz28's Avatar
Default quick question about spraying with my cam
i have a 224 112+4 cam. is that alright to spray on or should i get another cam. any help would be great. thanks
Old Feb 11, 2007 | 08:20 PM
DuronClocker's Avatar
Spray away! Nice color on that car, I was debating a color similar to that.
Old Feb 11, 2007 | 09:12 PM
99ccz28's Avatar
thank you! with my mods what kind of timing would have to be pulled for say a 100 wet shot
Old Feb 12, 2007 | 02:35 AM
Hooper's Avatar
Conventional wisdom states that 2 degrees should be pulled per 50hp of nitrous. So, for a 100 shot about, 4 degrees of retard would be advised.
Old Feb 12, 2007 | 03:21 AM
FANTA-Z's Avatar
Actually you dont have to pull any timing up to at least a 100 shot and have seen and personally ran my car with a 125 and no timing. The computer can handle pulling the timing out for that low of a shot. If you decide to go higher than those shots I would advise pulling the timing as said above 2 degrees per 50 shot.
Old Feb 12, 2007 | 10:43 AM
99ccz28's Avatar
so even with my cam being 4 advanced timing i wouldnt have to pull much or any with a 100 shot? thanks
Old Feb 12, 2007 | 12:55 PM
FANTA-Z's Avatar
From my experience most are 4 degrees advanced. I know my 306 was as well
Old Feb 12, 2007 | 11:40 PM
Phlip00WS6's Avatar
Id pull the 4 degrees out..
Old Feb 13, 2007 | 09:15 AM
SPRAYED 01's Avatar
Im pretty sure stock timing is about 23 total advance. Correct me if im wrong. I had my car tuned at 27 total advance and sprayed a tnt 150 shot.
