Which nitrous controller for a Turbo M6 car??
Old Feb 15, 2007 | 09:15 AM
anarchy99's Avatar
Default Which nitrous controller for a Turbo M6 car??
I've been looking into a few controllers nd just came across the Boost refrenced controller from NX. http://www.nitrousexpress.com/Pages/nxd5000.htm
My car is a forged 346 00' WS6 M6 with an incon setup and a wet shot spraying a very small shot for starters then working my way up. Would it be better to use the boost refrenced controller for my setup or should I use a controller like the dynotune one with 1st gear lockout? http://www.dynotunenitrous.com/store...?idproduct=194
I also saw this FJO controller from NX that looks really nice and can control other things like a shift light. http://www.nitrousexpress.com/Pages/...ndowSwitch.htm
I'll admit I've spent tons of time on my turbo stuff but not much time on my nitrous stuff. Thanks in advance for all the help guys.
Old Feb 15, 2007 | 09:59 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
if you are wanting to use the nitrous to help spool the turbo, then back the nitrous down as boost builds...go with the NX boost referencing unit.
If not the standard FJO is a very nice unit....it is one of our best sellers.
the window switch you listed gives the basic functions but the other 2 gives you much more control over the system.
I would go with the boost ref.unit if I were you.
Old Feb 15, 2007 | 10:11 AM
anarchy99's Avatar
I'm not really worried about spooling the turbos off the line because I'll use the 2 step for that. I had a direct port setup for the car before I went with the turbos and since I already had the nitrous, I figured I might as well use it in a limited capacity, I.E. small shots via a wet setup. I've also got meth injection in this car. Tell me, am I overdoing it? should I just get rid of the nitrous stuff and mess with just the turbos and meth injection? The boost refrenced unit looks like a nice piece of work though... DAMN!!!
Old Feb 15, 2007 | 10:19 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
The boost reference progessive controller allows you to reference boost or time. This is the newest controller on the market. You can tailor your nitrous curve to offset any boost lag or low power area. With some time setting it up properly, you could have an extremely FLAT torque curve that does not fall off. Also the controll will allow you to multi ramp.
Link
Feel free to drop a line or email to talk about your wants or needs.
Ricky
Old Feb 15, 2007 | 10:26 AM
anarchy99's Avatar
thanks guys. Yeah, I think I'm going to go with that controller here in the next couple of weeks... I need to stop being cheap and just go for it right?! I'll be shooting you a pm soon.
