Actual rwhp from nitrous
Old Feb 22, 2007 | 04:53 AM
xxtheonlyxx's Avatar
Default Actual rwhp from nitrous
Quick question... When you spray a 150, 200, or 250 shot how much "roughly" goes to the wheels? And roughly how much torque is gained? I'm getting the last of my mods and I'm trying to determine some numbers.
Old Feb 22, 2007 | 05:29 AM
Nox's Avatar
Nox
depends on alot of variables - the first being manufacturer..some list kit hp at the wheels, while some list at the flywheel. consult the manufacturers u r considering. they can give you a close estimate.
then there is type of dyno used....other mods...tune....condition of ignition system...bottle warmer....yada..yada... u get the point.
Old Feb 22, 2007 | 05:53 AM
Yeah, thanks. I was hoping for before and after dyno numbers with an nx wet kit. Im looking for best, and worst case scenarios. I'm trying to see if my tranny needs to be modded some more without finding out the hard way again.
Old Feb 22, 2007 | 07:13 AM
slow trap's Avatar
well with an nx wet kit when i was lid only i used a 150 shot and picked up exactly 150 rwhp. after i did cam i richened it up and took out some timing and it dropped down in the 13x rwhp gain so i'd say nx is rated at the wheels.
Old Feb 22, 2007 | 07:39 AM
Bad Habit Bird's Avatar
Each company seems to rate them differently. NX is usually rated at the wheels, NOS seems to be flywheel, TNT under rates their kits (a 75 shot usually = 100 - 125 rwhp)
Old Feb 22, 2007 | 07:44 AM
KrautBurner's Avatar
I have the Nitrous Dave's 90mm wet kit
with the 100 nitrous jet (and 150hp fuel jet) running 11:1 A/F
gained 107rwhp and 235rwtq (full bottle)
I hit 395 rwhp (N/A)
385 rwtq
and 502 rwhp (on the bottle)
620 rwtq
one run after the other (nitrous)
ran it again (without warming the bottle back up)
lost 1hp and like 30tq (only about 2 min between runs)
Old Feb 22, 2007 | 02:01 PM
NOS4EVER's Avatar
I use T&T did a 407 NA with a 150 shoot 530 lost 27 hp but mainly due to tuning gas used, I think that will contribute to a loss or gain in the advertised h/p rating of the manufacture.
Old Feb 22, 2007 | 03:57 PM
Thanks for the info everyone. Based on that Im guessing I should be in the 630-660 range and my tranny is rated to 650rwhp. If I dont spray through the shifts I'll be cool. I'm leaning towards 630hp because I'm going with a conservative tune.
Old Feb 24, 2007 | 10:54 AM
2001z's Avatar
It really depends on the car and the tune !! some cars will react better to spray than others from what i have seen!
Old Feb 24, 2007 | 10:58 AM
bodydropped's Avatar
My NOS plate system seemed to be rated at the wheels.100 shot made 98 more hp and 200 tq and 150 made a 147 more hp and 251 tq.This was a lil rich so i might have made the extra couple hp if we would have tuned it a lil.
Old Feb 24, 2007 | 12:19 PM
MetallicTrans96's Avatar
My LT1 plate system from Nitrous Works with the 150 pills and 8 degrees pulled I made 430hp/550tq and with a timing increased on n/a the car made 320/340.My tune is pretty safe...
