Mini freezer for chilling bottles before filling?
Location: Richmond, VA Where fast cars, well......are hard to come by.
Originally Posted by Todd157k
Try Airgas. They're nation wide. I'm going to go set up an account with them to get mother bottles. My local N2o supply wants $200 for a 56 lb bottle so I know they're paying less than that from airgas. I'm going to bail on the pump idea unless one comes along cheap. Seems that you can get better fills just freezing the bottle and filling it. The price of a chest freezer is far less than a pump.
Originally Posted by Beaflag VonRathburg
Interesting thread.
I think just filling a styrofoam cooler with ice and water would work pretty well. Those things can get really cold and the cost would be relatively cheap. Provided you have a freezer with an ice machine.
OWN3D BY MY PROF!
Probably would be easier... but if you remember your chem classes, it's more about consistency. If you want a consistent outcome, you have to be consistent about your procedure. No way of telling how "cold" a foam ice chest is with ice. Also, the idea of a bottle heater out of the car will have little effect on a 56 lb bottle. After many hours of trying to heat it, you'll find the aluminum will dissipate the heat faster than you can warm it. HOWEVER.. wrapping it in a water heater blanket would be a great idea. 65 deg is a little chilly. I think it's 80 deg gets you around 950 psi. (someone correct my figures if they're off)
Originally Posted by cyipher
I did fills outta my house and have two regular freezers, one day i had all these show up to get filled lol. all were filled doing the freeze fill method
#32
1 Post
Any tips or tricks you can share? ie: temp of mother bottle, length of time freezing bottles, pressures???
#33
My local nitrous filler has an ancient electric pump that he can put 10# in my bottle at any temp. He says its one of the most reliable ways of ensuring a true fill. Ive been trying to scope myself out one, so I could just start buying mother bottles, but have had no luck.
This also ensures a complete empty of the mother bottle, so there isnt any wasted gas.
#35
Originally Posted by camaroextra
honestly an ice bath is the most efficient way to get somethign cold. Ice water makes a bottle cold 10x faster than just ice, there is exponentially more surface area. I learned that after years of experimenting with beer. thats just my 2 cents.
this is true...we use a big *** meat freezer filled with slushy ice water,,usually can fill a 10# inside 40 minutes....in the ice longer i can get 11-12#'s in a 10#er...
#38
For those interested in understanding this:
http://en.wikipedia.org/wiki/Triple_point
#39
When I had nitrous on my talon I froze my bottle. I would stick it in the freezer the night before. Splash a little water on it so it had a nice lair. The shop I had it filled up at charged a set rate for a 10lb bottle. So I would get barely over 11lbs in a 10lb bottle and it would cost me the same. It was pretty cheap also. I believe about 25 bucks for a 10lb bottle.
