for those with wideband
Old Feb 26, 2007 | 11:43 PM
99WS7's Avatar
Default for those with wideband
what are you seeing for A/F when you spray? What is a good A/F to shoot for. Thanks...
Old Feb 27, 2007 | 07:20 AM
slow trap's Avatar
i'd say 11:5 to 12:0 or so.well i guess it depends on how big the shot is i guess also. i'd say some people shooting something like a 100 shot may run alittle leaner.
Old Feb 27, 2007 | 07:34 AM
ShaneD_06GTO's Avatar
11.8 is usually what people shoot for with nitrous.
Old Feb 27, 2007 | 10:20 AM
nate-roth's Avatar
Shots 150 and under are generally considered safe up to 12.0 maybe even 12.2 or so. A lot depends on how much timing is in the car. I lilke to pull some timing even on the smaller shots as a saftey factor, many here feel comfortable up to 150 on stock timing. Larger shots are safer at 11.0-11.5 due to the extreme cylinder pressure and greater chance of detonation.
Old Feb 27, 2007 | 11:08 AM
Todd157k's Avatar
12.2 on the juice... 12.8 off
Old Feb 27, 2007 | 11:50 AM
99WS7's Avatar
Thanks for the replys. Right now Im seeing about 12.2ish wot with out spray and its pegging to the bottom at 10 on spray. I only sprayed a few times to make sure my nitrous was coming on and working. I still need to be tuned with my new H/C and I know Im running pretty rich. How do I get tuned to have the propper A/F on spay and with out it?
Old Feb 27, 2007 | 01:27 PM
Todd157k's Avatar
You running wet or dry and which tuning program?
Old Feb 27, 2007 | 10:32 PM
99WS7's Avatar
wet, 100 shot. I don't have a tuning program. Im getting tuned at TSP next week.
Old Feb 27, 2007 | 10:45 PM
00Vette's Avatar
I always thought 11.5 was where you wanted your A/F to be for around 150shot. So you guys are saying to shoot for 11.8?
Old Feb 28, 2007 | 12:02 AM
SmaknaSS's Avatar
I shoot for 11.5-11.8 AFR on a small 150 shot. 11.5 @ max torq.
Old Feb 28, 2007 | 12:17 AM
Todd157k's Avatar
Until you get a program and log some data, I think the only thing you can do is check your fuel jet. 10s are pretty rich. Try looking at your plugs too. That will verify the AFR. Without a tuning program, you're shooting in the dark... and that's a little dangerous.
Old Feb 28, 2007 | 07:29 AM
nate-roth's Avatar
When you get your n/a tune leaned up, it will lean out your spray shots some. Your probably gonna have to go down 1-2 fuel jet sizes if you are at 10:1. Go one size at a time.
Old Feb 28, 2007 | 02:43 PM
99WS7's Avatar
Thanks for the advice. I will look at a few plugs to see what kind of info they give me. Im not gonna spay it anymore untill I get tuned. I need to get a program so I can do some data loging. Whats the main one everyone is using.
Old Feb 28, 2007 | 02:59 PM
Todd157k's Avatar
This is a link to the sticky under tuning. Lots of good info. Both EFi and HPt work great. EFi has an "auto tune" feature now, HPt will have it very soon. Check them out.
https://ls1tech.com/forums/pcm-diagnostics-tuning/368718-read-me-best-ls1-tuning-software-best-scanner-best-handheld.html
Old Mar 1, 2007 | 09:26 PM
nate-roth's Avatar
EfiLive and HpTuners are the two popular programs. Both have similar features and costs. I've used efilive with good success, friends like hptuners as well, so either/or. Both will take some time, you'll be shocked at how many differen't parameters you can control.
Old Mar 1, 2007 | 10:38 PM
99WS7's Avatar
Thanks a lot for the info. Now if I could only find one for a decent price!!
Old Mar 1, 2007 | 11:16 PM
00Vette's Avatar
I just realized that this was Paul!! How the hell are you doing. I too and worried about my A/F for my setup. I just put some 175hp jets in the car and finally installed my wideband. So I'm trying to dial it all in.
When are you supposed to dyno the car?
Old Mar 2, 2007 | 10:46 AM
99WS7's Avatar
Hey bro...just noticed this was you too. Im scheduled for Tue at TSP. Hopefully can make it. My **** needs a tune bad. It leaning out pretty good. Im running out of injector for sure. Im seeing 14's right now at WOT...Im gonna chill on the car untill I get tuned. I see a good average of 14.6ish low 15 at idle and cruising.
Good luck with your car bud!!
