Help me decide which way to go
https://ls1tech.com/forums/removed-locked-thread-graveyard/649117-nitrous-accessory-basics.html
https://ls1tech.com/forums/removed-locked-thread-graveyard/626209-dry-vs-wet.html
You let me know how the Hanabal 8 is running.... and I'll be dressed in white.
I would recommend 42 # injectors if your gonna spray a 150 Dry in a two stage Dry combo.
Robert56 is running multiple dry stages. Hit him up also for some info.
As for redundant noids, for a stuck open nitrous noid, I would just close the bottle remotely. Being the Nitrous would be read by the MAF in that case, it would get the fuel it needs. I believe Robert56 had this happen and did not not hurt anything.
