Lean on nitrous run AGAIN, help please!
Old Mar 5, 2007 | 12:40 AM
ShaneD_06GTO's Avatar
Would my duty cycle being over 80% cause the leaning?
Old Mar 5, 2007 | 12:54 AM
Beer99C5's Avatar
I do not think so.
Again IDC is pretty much a Dry issue, and has nothing to do with wet. I agree with Robert, pump is likely the issue.
My duty cycle was 106% and it kept up with a small Dry shot...
Here is what it looks like when the injectors cannot keep up with a Dry shot.
Here is a 150 plate (wet shot)
Same car but wet vice the dry shots shown above.
Old Mar 5, 2007 | 01:04 AM
Thanks for the graphs. It puts things into perspective a little better. Looks like I'll be ordering a fuel pump. Should I upgrade the injectors too? I know for a dry shot I should, but would it be overkill for some 42#ers?
Old Mar 5, 2007 | 05:35 AM
2001z's Avatar
Originally Posted by Beer99C5
I do not think so.
I agree pump could have a little problem with it but i had a racetronix kit and hotwire kit and mine did the same thing and tunning and rejetting fixed the problem . I believe a standalone system would solve the whole thing without aggresive tunning in certain rpm bands! Just my .02$
Old Mar 5, 2007 | 07:55 PM
Robert56's Avatar
Quote:
Originally Posted by Robert56@NitrousDirect
A Racetronics fuel pump should do the trick, talk to Matt at HSW. DC is only a concern spraying wet.
Robert
Okay. I am spraying a wet shot...
Sorry I meant to say dry hit is only concerned with DC. Unless your running out of injector n/a, no worry with a wet hit.
Robert
Old Mar 5, 2007 | 10:26 PM
Robert
Robert
Injectors are fine. Robert, would an lpe boost a pump work?
Old Mar 5, 2007 | 10:36 PM
Robert56's Avatar
Sure would/could, and you can wire it to come on only while spraying. It does look like a supply issue, because it finally catches up so bigger jet is not needed. What about your fuel filter, a new one?
Robert
Old Mar 6, 2007 | 09:07 PM
formula87350's Avatar
Another question, I remembered that I de-screened my MAF, could/would that cause me to run lean? Just trying to throw out all the things I think might have even a slight chance of causing the problem.
Old Mar 8, 2007 | 04:42 PM
WS6HUMMER's Avatar
I would put a fuel pressure guage on it and see what you got, also pull the fuel solenoid apart and look at the seal surface. It shouldnt be domed, only have a ring or depression where it contacts the noid orphace. Otherwise it should be nice and flat.
