Need some help...something with my set up not working right
Old Mar 7, 2007 | 10:00 PM
99WS7's Avatar
Default Need some help...something with my set up not working right
So I have a TNT F1 kit with a nitrous outlet TPS/WOT in one unit and for some reason when I try to spray only my fuel noid opens. I took my power wire from my nitrous noid and touched it to the + on my batt and it opened right up so I know its working, I also tried running good size wire(about 16 gauge) from my batt accessory post right to my realy to make sure it was getting not only good volts but current and still, only my fuel noid is opeing. This was all on mon when I was having my dyno tuned, I havent had much time to mess with it since. Only other thing I can think of trying is moving my ground. I have both the fuel noid and nitrous noid grounded to my passenger side head, will giving the nitrous noid its own ground help?? Im lost as hell. Its all wired correctly just dont understand why its not working. Any ideas on what I can check or do. Thanks!
Old Mar 7, 2007 | 10:22 PM
sprayin'99ss's Avatar
It would seem if it will open when you hook it straight to the battery, its the + wire, but you already know that. Try a different relay... re-run the + and - and try again, all I got and its nothing you probably didn't already know!
Old Mar 7, 2007 | 10:38 PM
99WS7's Avatar
Thanks for the input...some is better then none. I actually have tried a different realy aswell.
Old Mar 8, 2007 | 09:20 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Move the ground...aluminum is not the best place to ground the kit
