N2o kits
Old Mar 12, 2007 | 12:03 AM
Slow00ls1T/a's Avatar
Default N2o kits
I am putting together a wet kit
I have solenoids nozzle and bottle
do any sponsers sell kits that include everything im missing
Old Mar 12, 2007 | 12:27 AM
911ss's Avatar
i think dynotune sells a kit for the rest of the parts but it is everthing but bottle. check out there site and their ebay adds
Old Mar 12, 2007 | 06:13 AM
Lythropus's Avatar
I'd just go to nitrous outlet and piece together the parts your missing, their site is easy to order lines from in different sizes...
You need a main feed line (probably 4an ~16ft.-depending on your bottle nut)
An adpater from your main feed line to the nitrous noid (probably 4an to 1/8"npt)
out of the nitrous noid you need 1/8" npt to 3an
then a 3an line from nitrous noid to nozzle
You need a 4an line from the fuel rail to the fuel solenoid
another 1/8" npt to 3an adapter out of the fuel noid
another section of 3an line from the outlet of fuel noid to the nozzle
This is assuming you have a 4an bottle nut, 1/8"npt fittings on your noids, and a nozzle that takes a 3an (I think all nozzles take 3an but i'm not sure).
16ft is an estimate depending on where you mount your noids, I'd mount them first and measure what lines you need...
You also need jets, I'd just buy a jet kit for a single nozzle setup, and a tune...
Old Mar 12, 2007 | 06:35 AM
860 Performance's Avatar
Thats a lot of little stuff, don't forget about the WOT switch, bottle bracket, Blowdown tube and adapter, and relay too.
You should concider buying a new kit (minus bottle) and selling off the stuff you have, it would certainly be less complicated, and probably cheaper too.
Vinny
Old Mar 12, 2007 | 04:55 PM
Nitro Dave's Nitrous Outlet's Avatar
Give one of our techs a call here at the shop. They will get an exact list on what you have and then put together a spread sheet on what you are missing with prices. The call is toll free- 1-866-648-7637
Thanks
Dave
