This the right white wire?
Old Mar 13, 2007 | 05:00 PM
motomike734's Avatar
Default This the right white wire?
i find i think the right wire for my window switch there is a few white ones but only one lit up with the key on. How can i be sure?
Old Mar 13, 2007 | 05:07 PM
gi8e7oi825's Avatar
Unless you don't have an f-body...
http://www.installuniversity.com/ins...ht_install.htm
Old Mar 13, 2007 | 05:10 PM
hey that helps alot. lol i think i got the right one its the bottom white one ill goo check. Do you just pull the bottom cover off?
Old Mar 13, 2007 | 10:33 PM
Brett H's Avatar
If you happen to have a '98, it'll be pin #35 I believe.
Old Mar 15, 2007 | 01:56 PM
01black's Avatar
i have an 01 and i used the #10 pin with white lead
Old Mar 17, 2007 | 07:37 AM
ciws20mm's Avatar
I have a 98 and am on the #35 wire, is there anyway it could be the # 10 wire because my bmn controller will not activiate?
Old Mar 17, 2007 | 08:00 AM
john3daly's Avatar
No, it's the number #35 on the top harness. '99 up it's the #10 wire from the bottom harness, as shown above.
Old Mar 17, 2007 | 08:10 AM
ciws20mm's Avatar
I am on my second window switch that still wont activate, is there a signal i can test with a meter on that wire?
Old Mar 17, 2007 | 09:28 AM
john3daly's Avatar
Yea. Mine reads anywhere from 4-7V with the car running. Not sure if you can test it w/o the car fired.
Old Mar 17, 2007 | 10:51 AM
Brett H's Avatar
Which window switch is it and did you set it up to run the 1 cyl program? Individual coil pack cars like f-bodies and Mustangs have to run it this way.
Old Mar 17, 2007 | 12:16 PM
ciws20mm's Avatar
It is a bmn window switch, and they have already sent me a replacement. i have installed that one anf everything else has been tested, but it will not activate, i know this becaese it has a green led that lights when it is active.
