timing tuner decision
Old Mar 16, 2007 | 12:39 AM
Disturbed Bird's Avatar
Default timing tuner decision
i plan on getting my car dyno tuned but i dont use my no2 all the time. would buying a timing tuner and having it tuned for highest hp in n/a form and no2 form on a 150 wet shot or is it not a high amount of shot to notice a big difference in power? it is a DD and i dont spray very often! and if u dont think i need it and wont be a big difference in hp loss what do think the amount loss would be?
Old Mar 16, 2007 | 09:11 AM
Matt@HSW's Avatar
HP loss will depend on the set up, where the sweet spot is NA. If you are looking for a max effort NA set up that you want to spray on going the TT route is hard to pass up.
Matt
Old Mar 16, 2007 | 03:09 PM
so how much do they run for
Old Mar 16, 2007 | 03:17 PM
Matt@HSW's Avatar
$250
http://www.harrisspeedworks.com/shop...cat=308&page=1
Matt
Breaking Stuff's Avatar
About 250.00.
Old Mar 16, 2007 | 05:59 PM
cool will be buying it from u soon?
Old Mar 22, 2007 | 09:16 PM
another quick question i already have a msd window switch will it work with it
Old Mar 23, 2007 | 11:57 AM
Matt@HSW's Avatar
You could if you really wanted to, the LS1 TT already has a RPM window switch built in to it, so you could see the MSD one and recoup some money.
Matt
Old Mar 23, 2007 | 05:27 PM
i might use it because i havea fuel saftey switch and everything is already wired. can i wire the fuel safety switch to it? and if i do keep it could i still use the T T with the msd window switch?
Old Mar 23, 2007 | 05:56 PM
Matt@HSW's Avatar
Yes & Yes, it'll be easier to just use the ls1 tt though.
Old Mar 23, 2007 | 05:59 PM
sorry one last question. what r the instructions to wire a fss to the TT and dosnt come with the TT. im on the order page and i saw a Coupon Code box. u wouldnt happen to have one would u.
Old Mar 24, 2007 | 09:48 PM
ttt..
