hooking up for tach signal on BMN WS
Old Mar 16, 2007 | 12:31 PM
Danger731's Avatar
Default hooking up for tach signal on BMN WS
How do I locate this #10 white wire. My PCM has no numbers the connectors all have letters. Any body gotta pic of the 02 Engine bay and can point me in the right direction ?
Maybe I'm not even lookin at the PCM ?
I tried searches on another site as well. Need a helpin hand ...
Old Mar 16, 2007 | 12:44 PM
iamsickofitall's Avatar
Old Mar 16, 2007 | 12:50 PM
Danger731's Avatar
So open it up and follow it down where I can get a good splice in and thats it ?, thanks
Old Mar 16, 2007 | 12:53 PM
i used a dinky little red wire tap from radio shack when i hooked mine up. worked fine with my WS and still working with my shift light
EDIT: actually, it was the same type as the one pictured here
Old Mar 16, 2007 | 12:58 PM
Danger731's Avatar
how do you pop that cover off ?, You don't need to losen the center 7mm bolt ?
Old Mar 16, 2007 | 01:01 PM
if you squeeze the ends of the cover, it will pop off. i can't remember if loosening of the bolt was needed
Old Mar 16, 2007 | 01:06 PM
Danger731's Avatar
thnks i'll go check it out
Old Mar 16, 2007 | 01:18 PM
Danger731's Avatar
damn, pulled the whole module out and still won't budge in the center. anyone know the technique ?
Old Mar 16, 2007 | 01:19 PM
Danger731's Avatar
got the ends off but its held up in the center
