DynoTune TPS/Window/Lockout question
Say you have two stages, first stage is set to turn on at 3000 and turn off at 6400 and then second stage has first gear lockout and activates at 3500 and shuts off at 6400. The second stage knows that you have already been through first gear by the first stage deactivating at 6400.
That's atleast my understanding of it.
This is my solution and hope it works...
Mine is going to be wired with a master arm switch and seperate switches for first and second stage. I can arm it when I'm on the freeway and want both stages (Or to select stage one or two independently) I can just shift to nuetral and rev it to the rev limiter with both stage one and stage two switches off. It will think I've already been through first gear, then I can just turn on either stage one or stage two, whichever one I want (or both
). Then when I'm at the track, I can still use the second gear lockout feature...Good luck and get some more advice besides me, I'm just figuring most of this stuff out...
That is exactly how that works.
There is a way around that if you are running 1 stage. Basicly you would set up stage 1 with the lock-out, and stage 2 with no lock out. Wire a selector switch to the output of the window switch will select stage 1 or stage 2. This way you could flip a swicth in the car to select gear lock-out or not.
Hopefully that is clear, if not let me know.
Vinny
You have the output wires going into the car on toggle switches. When they are off you give it a quick rev which simulates 1st gear, then you arm one or both, and hit it.
If thats what you have in mind that will work also.
Vinny
here is a modified diagram I found on the wiring sticky...I think it's from MR223 (spelling?)
I think I'm going to change it and put my FPSS's on the ground from the window switch...
