Heater wiring ?'s
With that said. I have a dyno tune heater and the instructions are very straight forward. I just dont know anything about wiring. My first question is whats the best way to find a 12 volt source. It seems in all the diagrams in the wiring sticky they attach directly to the positive side of the battery. Is that correct? Is there a 12 volt source I can splice in to in the trunk area, or is the battery the best idea? With the ground can I just find myself something metal in the trunk and bolt it down to that?
Thanks for those who take the time to help. Im not completely lost on this, I just need some conformation so I can be sure of what I am doing. Im sure Ill have other questions along the way but I think I can get by if I can get this info. Thanks guys.
Jim
Ground can be taken to the chassis in the heater location.
So I should put the connector with the big loop on it, directly on the battery post on the pos side? Thanks for your quick response!
Make sure that if you are grounding somewhere on the chassis, floorboard, or any painted surface that you scrape the paint off so that you get a good contact.
[heater]--->[switch]--->[fuse]--->[battery]
[chassis gnd]
[chassis gnd]
1.) Hopefully not too late, but I'd use heavy gauge wire for the power from the battery to the relay. I used 10ga only because they sold a spool of it, but I'd think you'd want at least 14 or 12. Its a long run, and the heater has alot of amperage pull. Likewise I'd use a similarly heavy gauge for the heater element ground.
2.) I'd throw a 30A fuse in there to be safe too, and put the fuse holder as close to the source (battery) as possible.
And yeah you can use the same spot for the ground for both the relay signal and the heater element.
Not too late. Ive got all the wire ran but only have everything connected to the relay. The heater came with 12ga wire and 18ga wire. The 12 only has enough to reach the power source. So I wired everything else off of the relay with the 18ga. I could easily go get some thicker wire and redo it all. What do you think? I mean if it came with 18ga, I would think it would be ok. Its a little chilly out now so Im going to wait a couple hours. Hope to hear back from you guys by then. Thanks again!
Basically the relay has 2 12-14ga wires and 2 18s. Keep consistent and use heavy gauge on the heavier gauge relay wires since thats the high current load side for the heating element. The 18s are the low current load side just for the signal.
Sorry for the diahrrea of the mouth, I think I do a bad job explaining things in words sometime!
