Fpss
Old Mar 25, 2007 | 05:16 PM
GT Griller's Avatar
Default Fpss
Ive heard that these sometimes cause some problems is that true? I want be safe when running the nitrous.
Old Mar 26, 2007 | 12:17 AM
Nitro Dave's Nitrous Outlet's Avatar
The FPSS is a great accessory to run. The problem is that most people really do not know how to adjust them.
Dave
Old Mar 26, 2007 | 02:54 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
Dave
I agree with you at that one! We test and precalibrate all our FPSS before they leave the door!
Dean
Old Mar 26, 2007 | 03:42 PM
BayAreaSS's Avatar
Dean
So if i was to order a FPSS from you guys it would already be set? so i wouldnt have to worry about setting it myself?
Old Mar 26, 2007 | 05:58 PM
stealth71's Avatar
Dave
Any tips?
Old Mar 26, 2007 | 06:22 PM
GT Griller's Avatar
Ditto
Old Mar 26, 2007 | 10:11 PM
LS1TECH Sponsor
Exactly!
Dean
Old Mar 26, 2007 | 10:19 PM
Demon_Speeding's Avatar
The problem seems to be that most users set them too high, so when there is a brief dip in pressure when the N2O system activates in immediately kills it causing a surging. The trick is to set it a few psi below that.
Old Mar 27, 2007 | 01:14 AM
BayAreaSS's Avatar
Exactly!
Dean
that is very helpful!
Old Mar 27, 2007 | 09:04 AM
MavrikTA's Avatar
So Dave, is yours already set? You know I bought that one a few weeks ago from ya and I took it off b/c I was told they dont trigger till fuel pressure dropps to like 15PSI...which by then, it is all over anyway.
Old Mar 27, 2007 | 09:52 AM
NHRATA01's Avatar
I tested one I got with Dave's plate kit last year, looks like it breaks continuity right around 40-45 psi. Thats probably a good point for the 60psi operating fuel pressure I'm seeing.
Old Mar 27, 2007 | 03:15 PM
MavrikTA's Avatar
Yes, I agree. I would set it to 45ish, myself. If this is the case with all of the sensors sent out, then I am putting mine back in.
Old Mar 28, 2007 | 03:37 PM
02' hawk's Avatar
Dave
How do you adjust them????
Old Mar 28, 2007 | 04:22 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
to adjust a FPSS,
1) verify that the bottle is closed and there is no nitrous in the feed line
2) remove the fuel line from the nozzle
3) activate the kit
4) using a can to catch the fuel flowing from the fuel line, slowly tighten the screw on the end of the FPSS until the fuel starts to fluctuate.
5) Back the screw off 3/4 of a turn
6) hook everything back up and you are done
Old Mar 28, 2007 | 05:16 PM
Tommyv8's Avatar
How do you adjust it with a dry kit?
Old Mar 28, 2007 | 07:02 PM
AZ2ENVY's Avatar
There isnt a Fpss with a dry kit .
Old Mar 29, 2007 | 08:51 AM
NHRATA01's Avatar
Sure there is. Losing fuel pressure on a dry shot will be just as bad. Usually goes on the end of the fuel rail.
Old Mar 29, 2007 | 09:15 AM
Todd157k's Avatar
ya. there should be. and the adjustment is just the same. It can also be done with an air compressor and a ohm meter or light bulb. Then it's off the car and no gas splashing out.
Old Mar 29, 2007 | 01:33 PM
AZ2ENVY's Avatar
Youre right , It didnt dawn on me till after i posted this stupid comment
