Time to whore out my bottle set-up
Old Mar 25, 2007 | 11:47 PM
Lythropus's Avatar
Default Time to ***** out my bottle set-up
Not currently in the car but it's just to nice to sit around any longer.
10lb. NX bottle, nitrous outlet bottle valve with their 6an bottle nut, 860 performance 180 degree blow down tube, 860 performance 6an wing nut, dynotune remote opener, 860 spare tire bracket and bottle heater/mount, NOS 3 outlet 1/8" npt splitter going to a dynotune gauge sender/860 pressure sensor/ and eventually a 45 degree fitting and nitrous pressure guage.
Old Mar 26, 2007 | 07:41 AM
Beer99C5's Avatar
The Best of everything!
I especially like the shower head for Heater switch/pressure sending unit.
Big fan of the Wingnut on the mainline!
Old Mar 26, 2007 | 02:48 PM
C_Rules's Avatar
looks nice where are you mounting it?
Old Mar 26, 2007 | 03:43 PM
BayAreaSS's Avatar
I like that 860 bracket. I think i will get one when i install my kit
Old Mar 26, 2007 | 04:31 PM
Lythropus's Avatar
Spare tire area...to bad I can't pimp it 24/7.
The wingnuts have very little clearance as well as the showerhead but they do fit just fine...the handle on the opener is just large enough for the 6an feed line wingnut to swing around inside of it unrestricted.
Old Mar 26, 2007 | 05:58 PM
stealth71's Avatar
Looks good.
Old Mar 26, 2007 | 08:45 PM
Loadre's Avatar
Where did you get the shower head at?
Old Mar 26, 2007 | 09:08 PM
99WS7's Avatar
looks good...yeah, where did you get the showe head? The 860 heater is awesome by the way!
Old Mar 27, 2007 | 05:06 AM
Lythropus's Avatar
Ordered it from nitrous outlet, kinda pricey but it was the only one that would work, the distribution blocks weren't spaced far enough apart.
Old Mar 27, 2007 | 06:27 AM
860 Performance's Avatar
Looks great, this look well thought-out.
Oh, and pimpin aint easy.
Vinny
Old Mar 27, 2007 | 09:30 PM
blacktransam's Avatar
hmm that extra port on the shower head looks like nitrogen push set up
Old Mar 27, 2007 | 09:41 PM
Lythropus's Avatar
I've already spent to much nah just a 45 degree fitting and a gauge.
Old Mar 28, 2007 | 12:35 AM
AZ2ENVY's Avatar
Here is a couple pics of my current 860 heater assy and extras assy
Old Mar 28, 2007 | 05:16 AM
Lythropus's Avatar
I haven't seen a nx jacket on a 860 bracket yet but that kicks ***. It fit over the top of the 860 bracket wing nuts?
Old Mar 28, 2007 | 02:34 PM
AZ2ENVY's Avatar
No i had to take the 860 wing nuts off and use the wing nuts off
of my old brackets
Old Mar 28, 2007 | 06:32 PM
Lythropus's Avatar
It seems like the opening for the brackets along the sides of the jacket are large enough to twist it around and expose the wingnuts? Can that be done?
Old Mar 28, 2007 | 06:50 PM
AZ2ENVY's Avatar
Yep that also can be done I went my route cuz i thought it looked
cleaner imo
Old Mar 30, 2007 | 08:30 PM
Lythropus's Avatar
One last question, can you put the blanket under the straps and let the bottom flap go under the bottom of the 860 bracket?
Old Mar 30, 2007 | 09:33 PM
AZ2ENVY's Avatar
Im having trouble picturing what youre saying . Could you explain
it a little different please
Old Mar 30, 2007 | 09:59 PM
Lythropus's Avatar
ok, put the blanket on the bottle without the center straps on it, slide the bottle into the bracket and then take the center flap and wrap it around the heater like you have it in your pic. So the blanket is between the bottle and the bracket straps. Then the wingnuts will be on top of the blanket and you'll be able to see the bracket straps. I hope that's more clear.
I don't know how well it would hold the bottle with the blanket in between the stainless bracket ctraps and the bottle.
Just imagine the picture you posted with the stainless bracket straps around the blanket so the wing nuts would show...
