What wire to use for TPS and window switch?
Info I have so far:
The TP is at the throttle body
TP 1 = pin 65 dark green signal is above 4v at idle and below 1v at WOT
TP 2 = pin 63 purple is below 1v at idle and above 4v at WOT
The APP is the accelerator pedal position sensor
APP 1 = pin 29 dark blue is below 1v at idle and above 4v at WOT
APP 2 = pin 32 light blue is .5v at idle and above 2v at WOT
I was also told: Tps should be the purple wire (Falling Voltage)
but 1v at idle and 4v at WOT sounds like rising to me
Can anyone confirm the correct wire/wires I can use?
TIA
It saves the votage the box sees at idle and WOT and activates the kit accordingly.
I just checked my dark blue wire which reads .4vat idle and 2.1v at wot.
Didn't check the light blue one yet.
TIA,
VInny
Info I have so far:
TIA
