HSW Dry Kit???
Has anyone run a HSW dry nozzle kit? Where did you put your nozzle and mount your noid? I that bout taking off my air pump and running through the air hose to my SLP lid to hide it and mount the noid wherer the pump was mounted. Thanks for any feedback.
I have an HSW dry kit. I have the 70 degree nozzle mounted on the passenger side of my MTI airlid. Sorry I don't have a pic. It is mounted on the main rectangular part of the lid in the middle of the passenger side. It is pointed directly at the opening. Hope that helps.
Originally Posted by ja02ws6
Thanks guys that helps alot just wondering what shot your running and how much did it help you?
So far I have sprayed the 75 and the 100 shot. The bottle pressure with both definitely makes a big difference. When the bottle pressure was around 900 or more I got a much better kick than when it was say 700-800 PSI. I don't have any track times yet, but from what I've read I can expect to see about a 1 second drop in my 1/4 mile ET with the 100 shot at 950 PSI. So I am hoping for high 11s with my mods with the right track conditions. Last year I ran 12.9 N/A. I would spray the 125 shot, but my injector duty cycle is around 90% with the 100 shot already and I don't want to go lean because of maxed out injectors. MY AFR on the 100 shot is around 12.1 so I am happy.
