Few Nitrous ???'s regarding HSW kit, Jet sizes + accessories... please help
I have the chance to buy a Harris Speedworks Sudden Impact nitrous kit for LTX.
My car is a 01 z06. I was told that this kit will work on my car with different jets even though it was made for a LT1 engine.
Now my questions is on the jet sizes. I was told the kit will work but i need to buy different jets. I was told I would need to buy a .024, .028, .031,
and .034 wide stem stainless steel jets. Does this sound right to everyone?
I dont know much about nitrous but I am doing my homework. As far as I know I just need to buy 1 of each size jets listed above?
anything else I need to make this kit work... I assume all the lines are long enough?
Lastly the kit I am buying comes with a HSW Fuel Pressure Safety Switch, Dyno Tune Nitrous Purge with manifold, Dyno Tune Nitrous Two Stage RPM Window/TPS Switch, Dyno Tune Nitrous Automatic Bottle Heater Controller, Nitrous Express Black Heater Element. Is there anything else I need to buy to run a 150 shot safely?
It also comes with NGK TR6 plugs. Are these the plugs most guys are running?
What type of gauges would you recommend to monitor the setup. Fuel pressure and nitrous PSI?
Thanks for the help guys really appreciate it
