Spraying on stock timing
Old Apr 8, 2007 | 03:42 PM
Danger731's Avatar
Default Spraying on stock timing
Who is spraying 100 shot or 100 + on stock timing ?
Old Apr 8, 2007 | 05:52 PM
derekderek's Avatar
I am spraying a 100 shot on stock timing. But I am running E-85 so I am less prone to knock I would think.
Derek
Old Apr 8, 2007 | 08:04 PM
99FRC's Avatar
I was spraying 100 on stock timing until this past week. Didn't have any problems with it, but figured I go ahead and get a tune while it was in for headers. Keep in mind that this is with stock heads and cam. Any mods to these would definitely require a tune.
99 FRC
Old Apr 8, 2007 | 09:10 PM
mrr23's Avatar
i've sprayed 150 on stock timing tables.
Old Apr 8, 2007 | 09:36 PM
Danger731's Avatar
I thought the rule of thumb was 1 or 2 degrees per 50 shot. Others tell me 150 doesn't need any timing changes.
Old Apr 9, 2007 | 08:14 AM
mrr23's Avatar
i was told, years ago, by NOS tech 1*/50hp. if you were to look at the stock timing tables, you'd see a dip in the timing down to 23* in the 4000 rpm range, then back up.
Old Apr 9, 2007 | 08:30 AM
Infantrymarine's Avatar
So, am I right in saying that you dont need a tune, if your spraying on a stock motor, up to 150? Is that safe? Or should I worry?
Old Apr 9, 2007 | 08:44 AM
brad8266's Avatar
I sprayed 150 on my stock engine/stock timing tables for a long time
 Michael S. Palmer
Old Apr 9, 2007 | 08:57 AM
Danger731's Avatar
A lot of people do spray 150 on stock timing, I just wanted to see people post up.
Old Apr 9, 2007 | 09:51 AM
Lythropus's Avatar
I've done 175rwhp on stock timing...
Old Apr 9, 2007 | 11:13 AM
slow trap's Avatar
i sprayed 150 shot on stock timing as well.
Old Apr 9, 2007 | 05:09 PM
Danger731's Avatar
thats 6 so far
Old Apr 11, 2007 | 07:55 PM
Sunset'01Z's Avatar
as long as you change plugs to tr6's i wouldnt worry about it too much.
Old Apr 11, 2007 | 08:10 PM
Razorbackfan's Avatar
I pulled 2 deg and had TR6's with a 150 on a L98 motor. I just followed the directions. I never tried it with stock timing.
Old Apr 11, 2007 | 08:46 PM
LS1rulz's Avatar
Just a thought related to this thread:
Most people with a bottle have modded a few things on their car. Enough that they surely have gotten a tune by the time they get a bottle. Which means their timing isn't stock.
Old Apr 11, 2007 | 08:53 PM
cantdrv65's Avatar
Post
I sprayed a TNT 150 shot on stock timing for the LIFE of my 99 Ls1 motor....114,000 miles. At that level a colder plug is more important than reduction in timing.
Old Apr 12, 2007 | 02:26 PM
Danger731's Avatar
ok I'll b safe stick w 125 shot stock timing, just change the plugs
Old Apr 12, 2007 | 02:37 PM
Z284U2TRY's Avatar
Is timing more important to be pulled on the low end or the high end of the rpm band? I figure when you are spinning higher on the top on end would the engine not be breathing less n20 than say when its is activated @ 3000.
What does your timing curves look like? What is your max timing on say 5500+.
Old Apr 12, 2007 | 02:40 PM
NHRATA01's Avatar
How much timing is "stock timing"?
I have 26 degrees now with a tune and will be spraying a 100 shot. Should I have the tuner back it off any?
Old Apr 12, 2007 | 03:05 PM
Z284U2TRY's Avatar
26 degrees seems low to me for n/a unless he tuned some knock out.
